Адаптер головок Hensel к генераторам Balcar Nexus A3200
Стаж 8 лет 1 месяц
Непрочитанное сообщение Impulsite » 21 май 2015, 21:11
Источник: http://photo.net/photography-lighting-e ... rum/00KfOE
Hans Strobl писал(а):although the Balcar user manual does say that the Hensel EHT 3000/6000 or Profoto Pro-7 or Pro-6 heads are compatible to their Nexus A3200, they are also saying that you should check for the list of available head adapters. The Nexus power pack has round flash power sockets accepting the Balcar 14-pin plug. Because the Profoto heads have the 12-pin plug, and the Hensel EHT heads the 20-pin plug you will have to get an adapter for each head. This should run you about US$ 250 or EUR 200 for each head. Prices may vary between brands, depending on the location of the trigger capacitors. The Balcar power packs have the trigger capacitors in the pack, and it is somewhat more expensive to adapt a head with its own trigger capacitor (e.g. Hensel)to the Balcar PP.
The image below is showing a Hensel to Balcar adapter (discontinued) made by Hensel. The box is housing the PCB with the trigger electronics necessary to adapt an EHT head to the Balcar PP . Similiar adapters can be purchased from Balcar dealers. Balcar ordering info: Profoto 120/230 V requires the # 30530 adapter; Hensel 230 V # 30534; Broncolor 120 V or 230 V # 30531; Bowens Quad 120 V or 230 V #30533.
Фото показывает адаптер Hensel к генераторам Balcar Nexus A3200, изготовленный Hensel и сейчас снятый с производства. Коробка содержит плату с электроникой поджига, необходимой для согласования головок Hensel EHT с генераторами Balcar. Похожие адаптеры можно приобрести у дилеров Balcar. Информация для заказа Balcar: Profoto 120/230 требуется адаптер # 30530 ; Hensel 230 - # 30534; Broncolor 120 В или 230 В - # 30531; Bowens Quad 120 В или 230 В - # 30533.
Розетка Hensel типа 20 штырькового DIN 41622, Balcar штекер круглый, 14-штырьковый.
