Morris Aquaflash F-III TTL, есть схема
Непрочитанное сообщение Impulsite » 30 сен 2015, 16:39
Подводная вспышка Morris Aquaflash F-III TTL (вебархив) также известна под названием Philips P-300UW.
Схема, раскладка проводов и список деталей:
D.W.Knight писал(а):Disabling the SP function:
For compatibility with the 4-wire TTL system used by Ikelite, the SP function must be disabled (the strobe will indicate an error condition if SP is not asserted when in TTL mode). This can be done in 2 ways:
1) Join SP to Rdy via 22K. The resistor can be squeezesd into the sync cable, inside the strobe connector.
2) Open the strobe, short Q18 c-e, or remove R59.
Electronic (thyristor X) SLR compatibility:
Electronic SLRs, such as the Nikon F801 et seq., instead of having a normal X-contact, have the X-terminal connected to the anode of an SCR. Such cameras are incompatible with the Aqua F-III because the strobe X-line pull-up resistor (R38) is only 220 Ohm. If the F-III is connected to an F801, the flash will fire once and then refuse to fire again until switched off and on, or momentarily disconnected from the camera. Increasing R38 to greater than 2KW drops the X-terminal current to less than the SCR holding current, but unfortunately also results in a spurious error message from the strobe in TTL mode. The problem is cured by adding a buffer circuit (inside the strobe housing) thus:
The 1nF + 100W input network prevents spurious triggering due to cable capacitance effects (especially when used with the Nik V). Without it, the strobe will trigger when transitions occur on the SP or Q lines.
Отключение функции SP (Speedlight present) датчика присутствия камеры:
Для совместимости с 4-проводной TTL-системой, применяемой в Ikelite, функция датчика камеры SP должна быть отключена (вспышка будет показывать ошибку, если в TTL-режиме не будет подтверждения от SP-датчика камеры). Это можно сделать 2 путями:
1) Соединить SP и Rdy резистором 22k. Резистор может быть помещен в кабель синхронизации, внутри разъема стробоскопа.
2) Открыть вспышку, замкнуть коллектор и эмиттер Q18, или удалить R59.
Совместимость с электронными фотоаппаратами:
Электронные зеркальные фотоаппараты, такие как Nikon F801 и т.п., вместо обычного синхроконтакта имеют синхроконтакт, подключенный к аноду тиристора. Такие камеры не совместимы с Aqua F-III потому что резистор R38, подтягивающий X-линию, всего 220 Ом. Если Aqua F-III подключить к фотоаппарату, то вспышка сработает только один раз и не будет поджигаться, пока не выключишь вспышку и снова включишь или кратковренно отсоединишь от камеры. Увеличение R38 более 2 кОм уменьшает ток синхроконтакта до величины меньшей, чем ток удержания тиристора, и приводит в режиме TTL к ложным сообщениям об ошибке. Проблема лечится добавлением буферной цепи (внутри корпуса вспышки), таким образом:
Цепочка конденсатор 1нФ + резистор 100 Ом на входе предупреждает ложные срабатывания из-за влияния ёмкости кабеля (особенно, когда используется Nikonos V). Без этой цепочки вспышка будет срабатывать, когда по линиям SP или Q будут проходить сигналы.
