Oceanic OS2001, OS2003, есть схема
Непрочитанное сообщение Impulsite » 30 сен 2015, 18:23
Подводные вспышки Oceanic OS2001, OS2003, вебархив.
Oceanic OS2001 простейшая вспышка без позможности регулирования энергии разряда. Во вспышке Oceanic OS2003 имеется коммутация конденсаторов, обеспечивающая два уровня мощности "High" (1800 мкФ) и "Low" (1200 мкФ).
D.W.Knight писал(а):Opening the strobe:
The control knob can be pulled out a short distance, freeing the switch from the operating lever so that the internal assembly can slide out.
Replacing NiCds:
Currently available D-size NiCd cells are slightly longer than the originals, causing failure of the front port O-ring seal because the port can no longer seat properly. The solution is to replace the battery with C-size cells. The strobe should still be capable of more than 200 full power flashes per charge, but note that the 14 hour charge rate for an industrial grade C-cell is 220mA, as opposed to 400mA for the original D-cells, which means that modifications to the charger will be needed.
OS2003 Low output setting:
Main capacitor is 1800mF in full output mode, 1200mF in low output mode, so low output energy is 2/3 of full output. The strobe could easily (and more usefully) be wired to give 1/3 of full output in 'low' mode.
Inverter Transformer.
The insulation used in the transformer absorbs moisture. If the strobe has been flooded and the transformer is damp, don't switch it on. To avoid internal breakdown, remove the transformer and place it in a vacuum desiccator for several days before attempting to use it. If this advice fails, the transformer can be rewound by hand (with new wire and new insulation), but it's a tedious job.
Открытие вспышки:
Ручка управления может быть немного вытянута, это освобождает переключатель от рычага и позволяет вытянуть внутреннюю сборку.
Замена NiCd аккумуляторов:
Современные NiCd-аккумуляторы размера D чуть длиннее, чем оригинальные, и вызывают нарушение в геометрии разъёма и надежности уплотнения. Решение в замене аккмуляторами типоразмера C. Вспышка будет способна сделать больше, чем 200 импульсов на полную мощность, но нужно учесть, что аккумуляторы размера C заряжаются в 14-часовом цикле током 200 мА, в отличие от тока 400 мА для оригинальных D аккумуляторов, это означает, что будет необходимо внести изменения в зарядное устройство.
Переделка на меньшую мощность в OS2003:
Ёмкость конденсатора в режиме полной мощности 1800 мкФ, в режиме малой мощности 1200 мкФ, так что энергия импульса составляет 2/3 от полного импульса. Вспышка может быть легко (и с большей пользой) переделана, чтобы получить 1/3 полной мощности в режиме малой мощности LOW.
Трансформатор преобразователя.
Изоляция, использованная в трансформаторе, впитывает влагу. Если во вспышку попала вода и трансформатор стал влажным, не включайте вспышку. Чтобы избежать внутреннего пробоя, извлеките трансформатор и поместите его в вакуум-эксикатор на нескольких дней, прежде чем использовать его. Если этот совет не пригоден, то трансформатор может быть перемотан вручную (новым проводом и новой изоляцией), но это утомительная работа.
