Дистанционное Управление мощностью вспышки Yongnuo YN-460
Стаж 7 лет 9 месяцев
Непрочитанное сообщение Impulsite » 28 сен 2012, 15:42
Дистанционное Управление мощностью вспышки Yongnuo YN-460:
http://www.diyphotography.net/control-y ... te-control
http://photography-on-the.net/forum/sho ... p?t=860695
Domjan Svilkovic писал(а):For me, an ideal strobist flash would be an extremely cheap manual flash that you can control remotely. Extremely cheap and remote control?! I am surely asking too much! But why is that too much to ask? It doesn't even have to be RF control - it can be IR. All that the manufacturer has to do is to add a IR demodulator chip (probably something like $0.1 when bought in large quantities) and make a slight firmware change to the flash uC (almost free). The Chinese IR remotes are something like $2-$3 so they could sell a remote-control-enabled flash basically without raising the price! When in 2010 someone like David Hobby, who is very passionate about the use of a manual flash and who can probably afford any flash he likes, has to walk a few meters and lower the light stand just to change the flash power.... and the cheap remote technology has been around for more than 20 years... it certainly seems like a huge missed opportunity.
To prove the point I have set out to build a cheap IR remote for my YN460 flash. Here is the result:
Domjan Svilkovic (автор) использует для регулирования энергии вспышки телевизонный ПДУ. Простенькая схема на программируемом контроллере PICAXE-08M, схема в сборе и подключение к вспышке:
http://domjan.fizika.org/p/yn460-ir-circuit.jpg
Программа для микроконтроллера: http://domjan.fizika.org/flash_remote-08M.bas или https://impulsite.ru/ctlg/yongnuo/yn460 ... te-08m.zip
Руководство по микроконтроллерам Picaxe: http://www.picaxeforum.co.uk/docs/datas ... anual1.pdf
Видеофрагмент: http://www.youtube.com/watch?v=2osloXHi6eE
Примечания:
  • Одна из проблем, которые автор пытался решить, это потребление энергии. Поскольку у нас нет отдельного выключателя питания для цепи, она всё время подключена к батарее вспышки и может разрядить её в конце концов. Чтобы уменьшить энергопотребление, автор сделал отключение питания ИК-демодулятора и перевод схемы в состояние с низким потреблением.
  • Чтобы вернуть приёмник в режим ожидания, необходимо открыть и снова закрыть крышку батарейного отсека. После этого начнет мигать светодиод и имеется 5 минут, чтобы послать любой ИК-сигнал от пульта дистанционного управления (даже необязательно ИК-код от пульта Sony). Если в течение 5 минут сигнал не будет получен, то приемник отключится и для его активации потребуется снова открыть и закрыть батарейный отсек.
  • Как только приёмник получает первый сигнал, он активируется и постоянно ожидает сигнальные коды сониевского пульта, он их понимает.
  • Дистанция, которую получил автор, довольно приличная - 15-20 метров на прямой видимости. В помещении с белыми стенами может работать и не по прямой - за счёт переотражения от стен.
  • Не должно быть особенно сложно модифицировать программу для других наборов кнопок, чтобы управлять двумя вспышками от одного пульта
Если имеются вопросы по изготовлению, можно задать их на форуме: http://www.picaxeforum.co.uk/forumdisplay.php?f=2
Используя идеи Домьяна Свилковича (Domjan Svilkovic), можно ведь дистанционно управлять не только указанной вспышкой.
